Wanted CARB!!! For my 75 FJ40
Status
Not open for further replies.
Just north of here
I am looking for a carb for my FJ40. It has a Holley carb on it now and I want to switch back to Aisan Carb.
I'll take a good condition, or a rebuildable carb.
PM me if you have one.
Thanks
here it is. It is a bit dirty, but it ran fine when I pulled it off for a rebuilt one. It did run a little rich, but I think that was due to a slightly high float level.
as you can see, everything is there to bolt this right on..... You may need to peice together the mechanical linkage for it though.
PMK
Pat, FWIW, that looks like a 76 carb. Did you look at the year code on the front of the air horn?
I might be interested in it if doesn't work out with cessna.
Mark A.
Mark, the stamped in code is E20......
20th week of 75??
I'm can't remember where I got this one, maybe one of the first PMC swap meets. it does not have a vacuum pot that my original carb has (bottom of pic 1), but I understood it was a 75, and that is why I bought it originally.
PMK
I just noticed it was missing the "idle cutoff solonoid" (I'm pretty sure thats what its called).... But I know where it is, so it will be with the carb, and it is good.
Mark, did I decipher the date code correctly?
What do you guys think its worth, make me an offer. I don't want to "give it away", and I certianly don't want to rip anyone off.
PMK
Status
