Replacing hard brake lines
WI
I expect it to be straightforward.
How many feet of 4.75 OD hose do I need for my 96 with ABS?
Do we have a preference for material?
I can get OEM lines for about a hundred bucks. Included fittings, already flared and bent, no wasted material. I have to do it in a driveway so it'd be quicker in this cold.
Just trying to compare the options.
Sorry, this is for both lines going from front to rear
Also, I can buy pre-flared lines from the parts store for cheap with the fittings and double flared.
For the OEM lines, one costs much more than the other. Are they different lengths? Apprx how long are each of the two lines? Can't find this amywhere. Thanks
Get OEM, I have found that replacement one's the threads are just not the same as OEM . I hope this saves you a headache OH yeah PB blaster on all the fittings if you have rust which it sounds like you do
Not completely sure which hard lines your describing but personally I'd by the OEM. Rather than take the time to bend and test fit what I'm assuming are the long lines that run along the frame rail to the back.
