Replacing Engine in 1996 LX450
Texas
My original engine bit the dust a few months ago so I sourced a very nice example from a wrecked LC.
I got the original engine out just fine but I am having a helluva time getting the replacement engine back in.
I first tried with the torque converter attached to the flywheel but I could never get it to seat all the on the transmission shaft.
So, I took off the torque converter and pushed it onto the shaft as far as it would easily go.
I spun it around and pushed on it a bit and assumed it was fully seated.
However, when I tried to get the engine back in I get the sneaking suspicion that the torque converter isn't fully seated.
Should I need to use much force to get it fully seated?
I spun it around hoping to catch the split halves of the torque converter tube on the pump if it weren't seated but it just spun freely. I assumed this meant it was properly seated.
Do any of you have any suggestions as to how I would be able to know the torque converter is properly seated in the transmission?
A good rule of thumb is that the front surface of the torque converter should be recessed in from the mounting surface of the bellhousing the same amount that the flex plate sticks out from the mounting surface on the back of the engine.
When in doubt...
I push the torque converter in all the way, then drop in the engine and man push it in being careful with the nipple once it is bout in pull it the rest the way with two longer bolts and draw it together
It took me a few tries to get the converter seated when I replaced my engine, I put in the trans and spun it while holding the center part and pushing back. When I say spun, I didn't just turn it while pushing, I gave it a good heave-ho so it was spinning, it stopped when it was all the way seated. You could still turn it but couldn't spin it. I must say the whole thing has to be one of the most awful engine changes I've ever done, there are so many wires, hoses, and whatnot in various hard to reach places......
This is the first engine change I've ever done and I'm doing it by myself with a Harbor Freight engine hoist... Everything else seems much easier than the actual remarrying of the engine and transmission. At this point I'm looking forward to all the tedious wiring harness stuff. Thanks for the help.
