replacement Radius Arm mounts?
Austin, TX
Does anyone know if you can buy just the radius arm mounts that mount to the front axle? I'm trying to flip the mounts but having all kinds of trouble cutting off the original mounts in a fashion that they might be reusable without damaging the axle tube. I'd rather not build new mounts from scratch. Any ideas?
Yes they are available. Do a Google search for "fzj80 radius arm bushing" there are 4 for the front and two for back. All 6 are a bitch.
They're available aftermarket poly by whiteline, which is what I use. I use whiteline site for the part lookup then look up the part on Amazon or eBay. I think Slee sells the whiteline bushes as well.
If you need castor, ome has bushings available as well.
Should also be able to get them from a dealer for about the same price.
I'm talking about the metal bracket itself welded to the housing.
Sorry, I must have misread the first post. :doh:...... but please post back what you figure out tho. I'm interested to learn more. I have a similar project in the near future with my rear axle. Damn rust.
