replacement radiator suggestion? and alil tec help?
phx by CBT
ive got a crack on my 2002 4runner's radiator running along the top of my radiator on the plastic ive patched with JB weld for the time being. anyone have any all aluminum suggestions or should i just stick with a koyo like the taco forums suggest? id like to crush the milkshake/ future plastic cracking issues now so i dont end up with them later.
also ive been getting a po300 po305 code for misfire, ive changed the twin tip plugs, wiring and flopped the coil around to see if the issue follows the coil and it didnt. should i go after injectors next or am i missing something? ive replaced everything OEM so i know its not some shotty wiring or single tip plugs.
any incite is much appreciated
