Saturday started around 8:30 and I started disassembling parts of the old engine that were going to transfer to the new one. A few brackets that support parts of the wiring harness & air intake assembly, the assembly itself, the coil packs and the tensioner pulley. I sandblasted the steel brackets and gave them a fresh coat of paint. Once the rest of the support team arrived, we moved the truck to the edge of the ramped driveway so I could power wash the engine bay. Before they arrived I had soaked everything down with engine degreaser. It still did not cut through everything but good enough for now.
While I was in the empty engine bay cleaning I wanted to inspect the driver side motor mount closer, because a few years ago there was a crack developing. It was noticed when I had some muffler work done and I patched it up as best I could at the time by removing the steering shaft and exhaust down pipe and having someone with more experience than me weld up the vertical crack on the frame. Fast forward to today and there was a visible horizontal crack on the top corner of the mount. Towers grabbed the Millermatic and I went and found some scrap 1/4" plate to shape into a scab plate. A few minutes later Towers had the original crack welded and then welded the scab plate over the top of the rest of the mount. A little black spray paint and it was time for tacos and lots of water.
Next I installed the plugs (anti-seize applied) and coil packs while Towers worked on drilling out my exhaust manifold bolts in the down pipes. New studs installed and set aside for later. My wife continued going through my ziploc-organized nuts & bolts and cleaned everything up in the parts washer. The only accessory I put on before we dropped the engine in was the alternator. You can't put the AC compressor on until you seat the crank position sensor on the driver side of the upper oil pan (that tricky spring-loaded one). The power steering pump was still in the engine bay and the air intake would just be in the way for trying to attach chains to the engine for hoisting.
We spent a little while trying to get the new engine balanced on the chains on the forklift and repositioned them a few times and utilized a ratchet strap to finesse it a bit. We got the passenger side bellhousing alignment pin matched up and quickly put a bolt through that side. Then I moved to the driver side and worked from the lower end as Towers jockeyed the forks and my wife manned a 3ft prybar. Finally the driver side alignment pin hit center. Hours had magically passed during this process, it was 3:30pm at this point.
Notice the difference in orange strap and chain alignments between above photo and below photo - we did this a few times . . .
Once the engine was seated I climbed around the bellhousing finishing off all the trans mounting bolts, some are 17mm heads and some are 14mm and you'll need all the socket wrench extensions you have in your tool box to get those top ones. Then the starter and all the power cables to the battery and main grounds. Towers was working on the wiring harness with a quickness. By the time I climbed out from under the truck, he had almost all the plugs matched up and the power steering lines remounted to the frame. The transmission cooling lines were also reattached. I got the CPS attached and then the AC compressor. Towers reattached the AC lines we disconnected at both ends and started pressurizing the system.
Next the new radiator went in and all the hoses. Towers started checking for leaks using a fancy vacuum system hooked up to the radiator cap. The same vacuum helps fill the system with less air ingested. I worked on getting the exhaust manifolds installed and the O2 sensor wiring behind the block. I had to crawl up on the block again using a foam pad to lie prone and reach down along the firewall to reattach the plugs. The plan at this point was to turn the key over with the EFI fuses removed so that the oil pump could bathe everything before firing it up for real. I turned the ignition and let it crank over for about 15-20 secs and then we did it again for another 10-15 secs until Towers felt it had developed some pressure. Fuses went back in and relay box closed up.
Towers was still filling the radiator with a funnel at this point, letting it gurgle in slowly. So, I was waiting on him to finish filling the radiator and apparently he was waiting on me to turn the damn key for real this time. To be fair, it had been a long day and I was feeling a combination of giddiness that we were done and exhaustion. He wanted the water pump to pull more fluid before removing the funnel (I knew this, duh.) I turned the key at 7:15pm and it cranked up with a belligerent bocka-bocka-bocka-bocka. . . I looked wide-eyed through the windshield as Towers peered into the engine bay. It was the driver side manifold that I had forgotten to torque down
I turned it off, but also noted that the 4WD light was flashing on the dash. I asked Towers if he had plugged in the ADD actuator while he was on that side. Negative. I crawled under and tightened up the manifold bolts and found the ADD harness. We cranked it again and it sounded just like it should. Let it run for a few minutes and I look down at the table that all my parts were sitting on and see the front driveshaft sitting on the floor. I left the truck running at Towers suggestion and worked quickly to reattach the DS while avoiding the heat coming off the cat.
After letting it idle for about 20 minutes and checking for any visible leaks to any of the systems I took it around Commerce Circle a few times, first at about 20-25mph, then about 35-40, and finally around the back straight I opened it up to 55 briefly. Each time I passed the swingers club and Club Wax to the bemusement of each establishment's bouncers. It was 8pm and time to call it a day. I went back to the garage and told my crew we had succeeded. Towers said he would lock up the garage and me and
packed up a few of my things and headed home. I still have to go back and retrieve the folding table we brought and pack up the extra parts that were ordered "just in case".
I thanked my friend Towers from the depths of my aching body for all his expert work and I think he was equally excited that Dig-Dug gets to keep on keeping on.
