If you are seeing engine oil inside the distributor, and it's not coming in through any of the breather holes (as mentioned above) or the packing (seal) that fits around the distributor cap, it may indicate that the (internal) shaft seal is leaking. You could keep an eye on the leak by checking under the cap every few thousand miles, but first clean the inside of the distributor (use aerosol electronics cleaner, never carb/brake cleaner), make sure the packing seal is in good shape, and fix all the other oil leaks on the top/front of the engine.
If the leak turns out to be from the distributor shaft seal it is a big job to replace as this particular distributor is not designed to be taken apart. Also the shaft seal and shaft bearing are both unique parts designed by/for Toyota (not available separately) although there are substitutes that will work. The most painless route IMHO, if a shaft seal leak becomes major, is to buy a new distributor housing which comes with a new shaft seal, new shaft bearing, and new electronics. All you need to add is a cap, rotor, and seal packing.
If your spark plug wires are the originals (the date of production is stamped on the wires) it might be more economical in the long run to just buy a new set of OEM Toyota wires from a Mud vendor who will give you a 25% discount. HTH's.
