Warning...I went more detailed than I planned.
Issues with IDLE can actually be a lot of separate things that all need to work in conjunction.
IDLE and Throttle issues could be these and more:
- low voltage to the Throttle position sensor (TPS)
- Poor behaving or dirty Idle Speed Control Valve
- Clogged PCV
- Clogged vacuum ports on Throttle body
- Dirty throttle body
- Bad vacuum lines (clogged or split)
- Air leaks in the intake
- Dirty mass flow sensor/low voltage to mass flow sensor.
- Other sensor voltage issues
Since the throttle bodies primary job is to meter air into the engine unlike a carburetor that meters air and fuel. TPS sensor that is attached on the side of the throttle body and connected to the butterfly valve to tell the on-board computer how OPEN/CLOSED the valve in the throttle body. There is less chance it is the actual throttle body and more chance there is a member of the supporting cast that needs to be addressed.
When I had some work done on mine, they maladjusted the throttle cable. This caused the butterfly valve to remain open and never let it fully close. This meant the TPS was also out of adjustment because the valve was more open than the TPS was reporting at idle. This caused my engine to surge and pulse because the computer was trying to normalize what all the sensors were telling it. Since there was more air and less fuel entering the combustion chamber, the engine was surging and idling very rough because it was trying not to stall from the lean fuel condition caused by too much air volume at idle.
Do you have a service manual? there are some troubleshooting sections that could help you out.
