Replace Head Bolts One At a Time?
There is this phenomenal document called the FSM that basically tells when to reuse or not reuse a head bolts based on specifications in this said phenomenal document.
So, based on this document it is actually quite easy to tell when one should reuse or replace a plastic region head bolt.
Understood. I was commenting on the folks who weren't concerned with removing one bolt at a time, hoping to not disturb the gasket or mating surface.
Gotcha. That's a different ball of wax.
The FSM, again a phenomenal document, states that all head bolts should come off in a diagrammatically opposite fashion. So, if you take one off of #6 on the PS side, you should take one out from #1 on the DS side.
Mirror image, front to back.
I asked the forum once about re-torquing head bolts and everyone was against the idea so I would say don't do the one at a time method.
I asked a forum once if a witch would float and they said only if she weighed the same as a duck. So we burned her at the stake... 'cause ducks burn ya know.
You just have to love internet forums. ;)
Mark...
Laugh all you want, but I know consensus does mean something.;p
Mark...
Informed knowledgeable and experienced people reaching a consensus... always worth listening to.
General internet forum consensus, where more people base their opinions upon what they hear other people say in internet forums than on any real knowledge or experience... it carries less weight than the electrons used to share it.
Mark...
Ok so you're assuming that I'm basing my consensus on misinformed people?
Mark...
Nope. After the correct answer had been provided to the OP by knowledgeable and experienced people, your contribution was to disagree... with a basically meaningless statement that nameless and faceless someones somewhere on the Internet had led you to think it should not be done that way.
I was and am only pointing out the complete lack of value in this.
Mark
Mark
Other than that, totally helpful ;)
I am no "pro", I have replaced the HG on my 80 in 2011. After doing that job, I just wouldn't be comfortable removing/replacing one or two HG bolts. My $0.02 worth...
So the consensus was to not replace the head bolts one at at a time correct? So what are you talking about?
Mark
Sorry to stir up an old thread. I'm in the middle of rebuilding a motor. As I was torquing down the head bolts a couple stretched and I lost confidence in this set I got from Engine Tech. I ordered ARP's this morning. I havent filled with fluids, but am thinking without ruining the gasket I could replace the bolts singlely in reverse order - is that logic sound?
I wouldn't. I'd pony up for a new HG. It's way to damn much work to get from where you are back to replace it again if you guess wrong. Not worth the risk to me.
