any hints or tricks to getting to the bell housing bolts on top?
Yep, remove the engine with the transmission and then separate the engine from the transmission. I suppose you could leave 2 easy to access bolts in the bottom. Then remove the transmission isolator mount and engine mounts and attempt to elevate the rear of the trans and lower the engine. Then you might be able to get the top bolts out. Then lower trans and raise engine and reinstall the isolator. But once you go through that you might as well just remove the transmission cross member and tilt that bad boy up sharply and pull the whole engine and trans out.
