Removing the rear drums...
I'm missing something. I need to get my rear drums off so I can inspect all the stuff. As it is, they don't stop at all. I tried to just adjust them, but the adjusting wheels seem to be stuck.
I've obviously removed the wheels, and the small screw on the outside of the drum. But the drum seems to be really stuck/siezed on the inside. It won't budge at all.
I feel like there's some trick (Maybe with the big disk with the two nubs on it in the center of the drum) to getting these things off. Anyone know?
Thanks,
Mike
Once you get it loose and moving, you may find a ridge on the outside of the drum edge (caused from not turning down- I never turn that's how I know) that will cause a hang up. You may have to turn the shoe adjustment gear from the hole in the back plate. Once off you'll proly find cyinder and/or axle seal leakage preventing proper brake functioning (most of us have been there done that).
Good luck.
John
Second the big hammer. I use a small sledge, be careful not to break the drum, but you'll need to whack on 'em. Pads may have worn into the drum creating a lip on the drum so if you can (I know you said they were stuck) back off the adjusters.
BFH. Or two, one from each side.
If the drums don't move at all then they are rusted on. It happened to my daughters FJ55 too while we were restoring it. Some WD40/PB Blaster or whatever you like to use where the drum fits over the axle flange (same area as the hole for the hub in the wheel), some time for the stuff to work and then a big hammer, but like others have said, don't bust the drum.
If the drums move a little then the shoes are catching a ridge on the inner edge of the drum. Back off the adjusting wheels inside (through the oblong hole at the back) and the drums should come off.
JASUS! I gottem! To my surprise there was no lip hanging on the pads. A buddy had told me about that and I tried to comress the shoes as much as possible. I managed to get one of the four cylinders to adjust properly. I feel like an idiot, I've had the rig 2.5 years and have NEVER paid attention to the rear brakes. Turns out they haven't done a (&)*&^ thing since I've owned the rig. So $650 later I have new parts coming. Probably could've gone to discs, but a. I dont' have the time or pacience, b. I read some comments and I think I like the power of the drums, oh well, it's only money.
I got them off by beating the $h!t out of them on opposite sides. Eventually there was enough of a gap for me to stick my scraw driver in the hole of the drum and start wedging it away from the wheel/axle. Two bent scraw drivers, a headache, a lot of passer bys pissed cause I was makin' so much noise and some bloody knuckles the dang things poped right off!!!! Once inside I found that nothing works. And they probably haven't for awhile.
So I'll paint the backing plates and drums up nice, got new inerds on order and soon I'll experience the true magnificent braking power of the rear drums... I hope.
I've also got a new master cylinder and front calipers comin!!! yay.
When you slam on the brakes and end up in on coming traffic... it tends to motivate a person eh?
Thanks for everyone's help.
Mike
$650???!!! I have some brake parts for sale!
PO of my rig had a free fix for the rear brake problem. Beat the crap outa the hard line against the axle (appears the rear slaves were leaking). Flattened the rear line, stopped the leak. Had to replace everything from the T out. Got my parts from CCOT, probably not the best but a whole lot cheaper. Seem to work ok.
Les
