removing front drive shaft
Buckley, WA
I'm going to be driving from los angeles to charlotte n.c. in a months time. Is removing the drive shaft for the trip going to save me that much mpg... or not bother and keep it on.
Look up a thread called "removing vc" or "removing viscous coupler" or something like that. Since these trucks have a viscous coupler they are All Wheel Drive and won't drive withthe front off unless you loch the center diff. But even you do that, since the hubs don't unlock and freewheel, you are still turning all the stuff in the front axle so it's not likely you'll gain any mpg.
You can convert these trucks to two wheel drive by putting manuel locking hubs on the front and locking the center diff with the CDL switch. Or you could put some manuel hubs on the back and make it front wheel drive (lol) Anyhoo, from what I have read on this forum, the possible mileage gain isn't worth the trouble.
It will affect the handling feel as the front steering geometry was chosen with the front wheels receiving 50% of the torque, but I doubt you'd even be able to measure the fuel change. It's a placebo effect because as noted previously there is just as much drivetrain friction as without the shaft in place. Actually, your '92 truck does not have a the viscous coupling, and should be able to run with only the rear shaft in place.
DougM
With or without the viscuous coupling, the truck won't move without the center diff locked, and there won't be a noticeable MPG difference without the front hubs disconnected. (Or even much of a difference with them disconnected, from what I gather.) In short, the VC isn't the deciding factor, it's just an extra part thats removed when doing an actual 2wd conversion.
-Spike
Spike,
Whups, you're right - I was still envisioning the front shaft in place when visualizing torque. That little output shaft to the front will indeed simply spin so you'll need to push the button on your dash labeled "center difflock" Toyota kindly put on the 92s....
DougM
I noticed no gain in MPGs. I also noticed reduced stability. It turned really fast. It just didn't react the way I expected.
Friend of mine was driving from Utah to California and back in his 80. He'd done it once already and wasn't happy with the poor fuel economy. So, next trip he removed the front DS, locked the center diff, and put mini hubs on the front end so he could unlock the front hubs. He had measured his gas mileage before and after and saw about a 2mpg increase. He didn't mention anything about the steering, but he was on J's with no caster correction anyway, so he was used to squirrely steering.
+1 - Steering is super light as well.
some conflicting results here
Ran with the front d-shaft out for a month on my '92 FJ. 2 MPG increase in gas milleage. Just put it back in a couple of weeks ago, 2 MPG loss.
The steering is lighter, and the front lifts up like a normal rear wheel drive vehicle. Steering and handling were a little different, but not "squirly" or scarry to me. Actually drove pretty nice. Lost a little confidence in it on rainy day cornerring though.
It's back in now, and will stay that way. I need the 4x4.
92 fj80: 6 in slee lift, electric fans, 36" w/t
and...
'92 FJ80, with 32" BFG AT KO's on some aluminum 15x10 Mickey Thompson Classic II's, and 4:88 gears, slowly gettin' a rebuild to greatness... I love this thing!
You are likely to continue getting conflicting results. Neither of these are anywhere near stock trucks and the difference between 36" tyres and 32" tyres is significant as is the difference in gearing.
I'm with Curtis... Drop the front drive shaft, push the button, pray for no rain or slippery roads, and *accurately* measure your fuel consumption.
I am constantly amazed at the results people post and how they 'calculated' their MPG. First, you have to get a precise distance traveled. You don't get this from maps, road signs, or anything other than an ACCURATE odometer/Nav system/GPS or equivalent. You also need to get a precise quantity of fuel consumed for that distance traveled. You don't get this from the fuel gauge reading in the vehicle. (Don't laugh, one guy was doing this.)
You should also do an overall calculation by keeping a running total of the miles driven and the quantity of fuel consumed. This will even out those anomalies that we get when we travel down-hill for 6 hours with a 60 MPH tailwind.
-B-
My calculations are over 10 full-tanks of gas without the front d-shaft, with the 4:88's, roof rack, adv. timing, and tune-up.
And with the d-shaft, 2 full tanks of petrol, 4:88's, roof rack, adv. timing, tune-up.
I didn't, as I'm comparing the milleage with the gears and tires in both tests. i.e. with, and without the d-shaft.
The driving conditions are similar, although I can't vouch for the fact that they aren't identicle. Which, they on avg for my driving situation, are typical... now to just figure up my SD... :D
This may seem like a quibble but when you report a 2 MPG difference, you are not measuring a "mile" correctly since you have 4.88 gears and larger tyres. You can report a percentage improvement but you cannot accurately report a miles per gallon (MPG) improvement until you determine how far you actually travel when your odometer says 1.0 mile.
Think about it.
-B-
I understand what your saying, but with the same gearing and no change in speedo, mileage will be the same. I would understand making a % change allowance when comparing MPG from stock gears and tires to the 4:88's and roughly 31"s (stock off by about .2" with BFG AT 32"ers on a 10" wide rim measure 31.2"es). That change was from 9MPG to 15 without the d-shaft, tune-up etc.
This comparison is without any other changes except taking the d-shaft out.
I'll get all the math numbers up here shortly to show a more exact reading, but I found that basically it meant a 2 MPG change without the d-shaft.
MJADDICTION,
You are missing a fundamental piece. When your odometer says that your vehicle has travled 1.0 "miles", your vehicle (4.88 gears) has in reality, traveled 0.8 miles (as an example). Let's call this value an MJA. I can assure you that 1 MJA is NOT = 1 mile (5,280')
When you start your calculations, you are computing "MJAs" per gallon, not miles per gallon (MPG). To determine your real MPG (before and after DS removal) you need to get the ratio or you need to adjust or something.
Think about it.
-B-
Allright, I get what your sayin'. I'll just have to sit down and do the math...
