Removing cats
So, I found a shop willing to take my cats off (shhh!) and do the re-routing of the exhaust I have in mind...
my questions are:
Is it possible to re-route the exhaust to the inside of the frame rail to tuck it up without using a cat or a pair of them? From what I've seen under there, looks like there is room. Anyone done this or have pictures?
Also thinking of ditching the huge muffler for something smaller..not louder, I love how quiet it is, but to get it farther up for protection.
Will this throw a CEL from not having the cats? If it does, what sort of problems will that create? A rich mixture? Right now, I'm getting the EGR code and haven't addressed it since it runs great, mileage is great (well, for what it is) and I'm considering just leaving it alone and unplugging the light in the dash. It annoys me. :lol:
This is all in prep to protect the exhaust, get 180k miles plugged cats out and free up some horse power and I'm building my own sliders and honestly don't want to mess with a plate for the cats..which, in my opinion is just not a great design to begin with.
Thanks for the help.
cats
If I recall correctly from my mustang days with obd2 and living in California passing the visual inspection may be tough but if your not in cali and you can find the right person it should not be a problem cat wise. You can get a MIL eliminator that goes in the rear o2 sensor and sends an all good signal all the time, the one before where the cat would be should be fine as well. That should trick the computer into thinking all is good. However passing emissions is up to you.
--Sean
This has been covered before. The new design of cats allows for almost no restriction and is a definite improvement for the environment. Not running one is bordering on absurd.
Now, I have posted several things on aftermarket, and if your stock cats are toast or too big, search for my posts on the subject. I have an aftermarket 14" magnaflow cat in place of the two stock ones. No codes, no performance hit, and no increase in pollution. (installed for less than $200).
Do us all a favor and put something in there vs. not.
x2 - There is certainl good logic behind one vehicle not making nearly the impact as say a power plant, but everyone needs power, not everyone needs to 4 wheel. I say don't give the environmental extremist any additional amunition to use against us.
If you search you will find where i had my cats cut and turned onto their side. Really tucks them up and out of the way. Best part is it only cost $50 at the muffler shop to do it.
I think the problem isn't the cats, it's the pipe after the cats that goes under the frame! I would like to replace my dual cats for a single, aftermarket cat and then run the exhaust above the frame. It looks like there is a good spot for it above the second cat... right now I'm running both stock cats with a turn down... no other piping. The second O2 sensor is just zip-tied out of the way.
Look at my post. I am running a single 14" OBDII compliant cat...no problem.
Wow..I didn't expect this kind of response. :eek:
This is a technical question and thanks for the technical responses. To those with remarks about the environment, might want to ask more questions before popping off with ruining our air and dumping used motor oil on the streets. :lol:
Ask more questions like what? How else can we make our sport vunerable to environmental extremist?
Guess we could have just said "SEARCH" it's been covered a dozen times or more!
You could have.
SO..all the offroad buggies without emissions are ruining the sport for us? Awesome. :rolleyes:
I would have rather been told SEARCH..than got lectured on the environment and me destroying our sport by removing a piece of emissions equipment that is not required for my use of said vehicle. :idea:
:D I tend to stick my foot in it once in a while. :lol:
I was afraid of that, but it's a slight issue for what I'm trying to accomplish. Screw it, maybe I'll really piss everyone off and drop a LS1 in this thing. Without cats!:eek:
So you are saying you aren't going to register and plate this rig? Offroad only, trailer it in? I think this is as much a technical topic as the original question (which I did answer). If you have sensors and a non-OBDII system in place, you get codes, have a nice day. You can use bungs (illegal) to replace the sensors...again, if you register the vehicle it is illegal to do anything you are talking about...UNLESS you live in some interesting place that doesn't care...I don't know of too many of those anymore.
So, dedicated offroad, you are just fine to pump out as much crap as you like, just because everyone else is doing it! (best reason in the world, nevermind that you could have the same performance AND do a little to help the friggin world).
Actually...since you asked, I do in fact live in a DEQ free zone. But that wasn't the topic...but since it has become the topic I'm willing to bet that all of you who do drive 3 ton trucks that get the mileage equivalent of a big block dually, that we are all really concerned with emissions aren't we?
I'm not saying I want to kill mother earth...but being attacked and having people jump to conclusions makes me laugh at the mentality of some people. If you don't agree with me, fine. Just leave your ethical opinions to those who have to deal with DEQ. I do not.
I've been searching engine swaps and I have NEVER seen that person attacked that is asking about doing one. Funny. You applaud a 4BT swap or small block..but frown when catalytic converters are brought up. :idea:
Yes, it was said because....umm...it is against federal law to remove them? BUT...I as I KEEP SAYING....
I have no DEQ requirements, shouldn't that be the end of the issue?
:eek: Oh the noes!!!11111 :crybaby:
