Removing an Aussie Locker
Coweta, OK
Has anyone here removed an Aussie Locker? If so, can you please tell me how many bananas it would take to transfer from one third member to another?
I currently have a rusted up rear-end that is going to be replaced with a stock one I pulled from salvage and had blasted/painted.
I was wanting to move the locker over to the 'new' one as well, but I know nothing about these things and the instructions I downloaded from the manf website don't really talk about removing it.
If anyone has ever taken one out or put one back, I'd appreciate some pointers.
I haven't done it, but can't imagine it would be difficult, just gotta get the springs/pins out and the thing should come apart. The real dificulty would be getting the diff working again after removal, unless you kept the old spider gears. If you're junking the diff that you're pulling the locker out of, should be easy peasy.
Found this on the youtubes:
Thanks for the video, it makes it look pretty easy compared to what I was thinking. I expected to have to use some weird tool.
I was planning on moving the spider gears over to the old third, and storing it as a backup. I hate to junk a perfectly good third.
If it's a perfectly good third, why disassemble it?
@-Spike- , The one in my rear now is fully serviceable, but is rusted to hell... 3rd stage pitted and looks really bad (truck lived in Vermont for its first 20 years.). the one which was attached to the axle housing when it got blasted and painted looks great. So, purely for cosmetic reasons.
My logic is that the rear end would be easier to manipulate and install without that heavy ass third up there, and if I'm going to pull it. It would be an ideal time to move the Aussie locker over.
I've also been running Redline shockproof heavy in the rear for the past year or so and wanted to visually see what things look like. (my guess is slick and slimy). the shockproof really quieted down the clicks.
I installed an Aussie Locker on my 80 a couple years ago, once you have the 3rd member sitting on a bench its quite easy. Removing the Aussie Locker from the 3rd should take 5 minutes max and install is pretty straight forward. You will have to check the clearances once you install in the new 3rd so make sure to have a feeler gauge and some calipers handy (instruction are on the Aussie Locker website). If the clearances are out of spec you'll need new thrust washers, if the truck is your daily driver you might want to get some thrust washers ahead of time so you don't have to wait for new ones to be shipped if you need them.
Post up some pics of the Aussie Locker when you get it out, be interesting to see if it shows any signs of wear.
Pull the third, clean off mating surface, seal it off real good, get bluing/rust remover for steel and spray it on, let it eat the rust, then remove it. Spray paint or por 15 it after its rust free. Gotta be easier than swapping guts around
