I bought a 78 FJ40 recently, and somewhere along the line someone installed a lock right locker by powertrax in it. (in the rear axle) I will admit it is GREAT off road, but must admit I hate all of the clicking, clunking, and jerking it gives ON the road.
Since this will be a 75% ON road vehicle for me, I am considering removing it. (to at least see if all of those noises go away) Can anyone tell me what kind of job this will be? I have the manual for the locker, but it does not provide instilation procedures.
It's not too hard...I had to do it on the trail once.
You need the spider gears, their washers, and the middle spacer that came out when the locker went in.
I am not aware of a Land Cruiser parts house that has a 'kit', but you should not have any problem finding these items out here if you post up in the wanted section.
I have these, if you cannot find them local to you.
Thanks Poser. I will post an ad in there. Maybe someone will trade me the parts I need for the locker I am taking out. (assuming it is good) I appreciate your input.
I have the parts needed and would swap with you if you want to go that route. Neither the Lockright or the stock parts will weigh much so shipping would be on the low end.
It’s super-simple. I just did this a few weekends ago, and made it ~10x as hard as it needed to be.
Once you have the parts lined up (spacer block, spider gears and their washers) do the following:
1) remove the tires and jack the rear axle up off the ground 2) drain the diff and remove the cover 3) rotate the carrier housing and remove the pin, then rotate again to present the large opening towards you 4) remove the 4 sets of springs from the locker, and slide the passenger side toothed section towards the driver side (I applied a little wheel bearing grease to the teeth so they would stick together) 5) rotate the locker so the large slotted opening on the passenger side is facing down 6) bump the passenger side axle inwards, this should cause the c-clip to fall out 7) slide the passenger axle out 2-3” so that it disengages from the locker (careful of the axle seal) 8) remove the passenger-side locker components 9) bump the driver-side axle shaft in and remove the c-clip 10) slide the driver-side locker components out of the carrier housing 11) install side spider gears with the thrust washers that were on the back of the locker side gears and slide the axles in and install the c-clips, pull the axles back out to seat the c-clips firmly 12) rotate the carrier housing up or down to allow you to install either the top or bottom spider gear and washer 13) rotate the carrier housing the opposite direction far enough to be able to place the opposite spider gear directly opposite from it’s opposing gear 14) rotate the carrier housing and gears to allow you to place the spacer block, and slide in the pin
If I’m forgetting something, someone jump in and correct me. All told, it was about a 1hr job start to finish for me, after I uncomplicated it.
Hey... I REALLY appreciate the help! I have a few people willing to trade with me, so as soon as I can get a deal hammered out, I am going to dive in. Thanks Seth!! I am printing this as we speak!
I know that this thread is more than a decade old, but I found it super helpful and just used it as a reference to pull my Aussie Locker for winter. I do have one minor contribution to the list above. In step 4, the springs are removed from the locker, but I found I also needed to remove the pins that ride on the springs, otherwise the locker wanted to come out in one piece and couldn't fit past the ring gear. I used a dental pick to work the pins out.
