Remote Starter (shop tool) Hookup and Using
North Front Range, CO
I am asking about the shop tool hand held remote with wires not the remote starter that laze people use to warm up there cars (Puffers )
I tried to hook up the hand held remote starter, one end was to the bolt on bottom of the starter and other was on positive of battery. Pushed the button and the starter turned but it didn't engage the starter gear into the flywheel. Where do I hook up the wire on the starter?
When using the remote starter and I just want to turn motor over, what electrical connectors should I unplug, or what fuses should I remove?
Are you talking about a bump starter? You hook one clip to the positive battery, the other clip goes to the small slide plug on the starter, I usually just stick a coter pin into the small slide plug and leave it plugged in then hook your other clip to the cotter pin. I pull ignition coil plug and efi fuse.
I hooked it up to the nut/bolt with wire on it on bottom of the starter. It spun the starter but it didn't sound like the stater turned the motor over but I did have the spark plugs out so maybe it did turn the motor over and I didn't recognize the sound as I was under the vehicle. I will try again and watch to see if the motor turns over.
One connection drives the starter motor. If you power the other terminal separately it will engage the solonoid and kick the drive gear into the flywheel.
