Remote start problem
Norfolk, VA
I have a remote start on my rig, it was already installed when I purchased. I can remotely start the LC, but the lock and unlock does work. So the LC is nice and warm inside, but when the door lock is frozen, then I'm SOL and freeze my ass off trying to open it. in the winter time. Any suggestions or insight would be appreciated. Thanks
That feature may not have been installed by whoever installed the unit. This is an option thats costs extra and may never have been done..... If it has been done you will have get a wiring diagram for the remote start and start tracing wires.... probably a loose connection somewhere.
Just a thought... Do the power locks work from inside the truck by pushing the button on the door? If not you may just have a blown fuse.
AND WOW IKA1988.... you have apparently never seen the ice and snow we get up here in Canada... All too regularly locks freeze up and the key wont work, or is a MAJOR pain in the A**........
AND WOW LKA1988.... you have apparently never seen the ice and snow we get up here in Canada... All too regularly locks freeze up and the key wont work, or is a MAJOR pain in the A**........
I've had to deal with a frozen lock a few times, actually... Of course, it doesn't get AS cold as it does up there, so turning the key a few times usually breaks the ice. :D
Unfortunately I have actually bent a few keys up here trying to open a frozen lock!! Been lucky thus far and haven't broken one off in the lock..... Now i have a heated garage and never have to worry about it again!! :)
I experienced a similar issue when I purchsed my rig. Previous owner had installed an aftermarket remote start/alarm. The locks could not be operated by the fob but would auto lock 30 seconds after all doors closed. Based on the key fob I was able to determine the system manufacturer, then download a manual and re-program the system. I was able to program the system to have the key fob operate the locks and not auto lock.
Short answer is determine remote start system manufacturer and obtain manual.
Empty your PM box. I sent you a PM but it says your box is full.........Damn, that sounds bad:eek:......anyway, clean your box out!
Chans
My box is now empty. Learning something everyday here.
...but the lock and unlock does work.
I'm sure you fat-fingered it and meant to say that your locks don't lock or unlock after you remote start the truck.
I just installed a Viper (160XVL) remote starter with the lock/unlock feature. It works a bit odd and maybe you are experiencing the same symptoms. It took me a while to figure out what was going on, but here are two oddities that I have nailed down.
(1) If you get out of the truck and use the button on the door to lock the truck, you can't unlock it with the key fob. Even if you try to press the lock button on the fob before pressing the unlock button (to "fool" the remote starter into thinking it locked the truck), it won't unlock. I have gotten into the habit of never using the door button and always using the fob as I walk away.
(2) This one is odd. I'll offer it as a symptom, but it really doesn't matter in the daily scheme of things. If I am inside the truck with the doors closed and I hit the lock button on the key fob (as I said, there really is no reason to do this), then the lock/unlock button on the door becomes inoperable. Pushing the door button will not unlock the truck. In addition, the unlock button on the key fob is also inoperable. The only way to open the vehicle is to manually move the physical lock mechanism near the door handle.
I returned to the dealer that installed the remote starter to see if they could come up with a work-around for this (i.e. making the unlock button on the fob available after you had locked the truck with the door button), but they couldn't come up with anything.
I suspect this has to do with the factory alarm/keyless entry (as received from the PO, mine is junk and unresponsive to any keyfob I purchased) or the automatic door locking function. Can anyone shed light on this?
