Relay?
A little more specific. Is the starter not turning over? If not, did you try jumping the terminal from the solenoid directly to 12v positive with a screwdriver or a remote starter switch?
If that won't kick it, you've either got a bad battery, bad cable, or bad starter solenoid [most likely of the 3]
If it turns over with the screwdriver/ remote starter, but not the key, then chances are it's the ignition switch. Occasionally, the wiring from the switch to the solenoid.
Hth
Mark A.
I was having trouble with the electrical, lights didn't work then the horn. My bro-in-law said to clean the ground from the battery.
When I went to reattach the ground there were a few sparks so I disconnected the battery and attached the ground. It started fine once then wouldn't start again. Leaving me stranded. Didn't try the "screw driver" trick.
You can have a good enough ground to power lights, horn etc and still have a bad cable. Its the starting amperage draw that requires a good cable, both positive and negative. I just replaced both cables when I got a new battery, cost me about 20 bucks.
