So I finally got around to wiring up a relay in my passenger side front door. I referenced this in another thread. I got some 5 wire Hella relays, the 5th wire is not used, as it is for a normally closed circuit.
I wired the relay the following way:
1 wire to 12V constant (direct to battery through a circuit breaker under hood)
1 wire to ground
1 wire is the signal wire. When 12V is applied it activates the relay. I used the black wire coming out the DS switch, as this is the only wire that gets hot when the window is raised up. I tee'd off of this black wire, basically a three way connection.
1 wire goes to the black wire before the window motor. It also tees into the connection.
So, the same wire that controls the relay powers the load. This is, I believe, my problem.
The window goes down normally initially. When it is put up, it continues to raise even after that switch is let off, although slow. I managed to burn up a switch doing this. Also, the relay has to be unplugged and replugged before the window can be put down again. I'm guessing there is enough voltage being applied to the relay switch even after letting off the wondow control to keep it open.
What I can't figure out is another way to wire it. I need to have a wire that gets hot when the window up control is pressed. The only wire that does this is the same wire that goes to the window motor.
Any ideas wiring gurus? I'm hoping I'm missing something simple here, but I can't wrap my head around it. I really wanted to solve this slow window issue, which is being caused by insuffucient voltage making it to the window motors.
1 wire to ground
