Relay Rod causing pulling to the left?
I can't offer any help, but I'm hoping to piggy-back on your question.
The TRE on my PS drag link is shot. Though my truck tracks very straight if I let the wheel go, it seems ever so slightly off center in the counter-clockwise direction. I also get an occassional very slight side-to-side vibration in my steering wheel which I previously attributed to tire balance. To my knowledge, all the TRE are original.
Could the torn/shot TRE be the cause of my steering wheel vibration? Could it also be the cause of my off-center steering wheel? If not, can I adjust the drag link or tie rod to get the steering wheel back on-center?
Finally, should I replace all the TREs together (and maybe the tie rod and drag link also) or just the one that is shot, or does it matter?
End of thread hi-jack :beer:
5-ish inches.... I've got Frankie's springs and they are a true 4" lift and I put my adjustable spacers up front and 1 3/8" spacers in the rear.
Slee castor plates, OEM bushings. Never have adjusted toe.
way low on caster. get a sweep to confirm but you'll need Slee's arms to correct the pull.
hmm, when I bought the 4" springs last month it pulled just as much at 4" than it does now with the spacers in at 5", may be me not knowing but it seems to pull no matter the height. I'm unique in the fact that I've had 4 seperate spring sets and anywhere from 2.5" to 5.5" lift from OME medium, heavy, J and now Frankie. The only time I did not have castor plates was with 2.5" medium lift.
But you're right, I need my castor measured to see where I am.
OK, I'll center my axles by correcting my panhard rods, the rear will be sometime next week with the DIY I bought, after this weekends wheeling trip. Then I'll save for a DIY for the front or just buy the dang thing complete for "easy drop in" but "hard on wallet".
So panhards first
if nothing
Then castor sweep and correction
if nothing
then for sale section:mad::rolleyes:
Mine was pulling hard to the right when I was running those mismatched tires you sold me ;). Once I got new matching 285's it wandered bad but tracked straigt. I adjusted the toe using the tape measure method and the wandering was completely eliminated but it pulled slightly right. I adjusted the relay rod? and now it seems to pull slightly left. I think I am low on caster and compensating for a misaligned steering wheel.
Com'on maaaaan, they were worn, not mismatched!
We'll be at Morris Mountain this weekend. Some are camping Friday and Saturday night, I'll be there Saturday morning and camping Saturday night only... come on over at least for the day!
you are correct, and they served me well. I can't make it this weekend grrrr.
back on topic - why don't you just take it to an alignment shop that does free alignment checks and get your caster checked?
I'll let the other Matt I know on this thread answer the "free" alignment question...
Matt in B'ham, the Matt in Auburn is a manager at Franklin Tire here in Auburn... he hooks us locals up. But checking/adjusting toe seems to be too easy to pay over $50 for.
*** crickets***
Free alignment check? My technicians cringe every time they see a lifted vehicle.
My question is how would the caster be out on only one side?
If the caster was out due to difference in ride height, wouldn't it be equal on both sides?
If caster angles are equal then the vehicle shouldnt pull... (might wander everywhere)
*edit*
BTW, alignment is $75.00 for walk-ins and $65.00 for Mudders or WEC members.
And a special today for short rotund red-heads of only $10
What a special! I'll be in a lunch!
This is my thoughts and the reason I'm tackling the panhard before I even sweep the castor. Afterall... if I find my castor is off, then what? I'll have to get bushings and then find someone to put them in and not balk at the castor plates...
yep, very easy - if you had two people you could probably do it in less than five minutes. The hardest part about it for me was affixing the tape measure to one tire to pull it to the other.
Long arms makes this a lot easier......:grinpimp:
