Relay Rod causing pulling to the left?
Land Speeder
InstaH8R
Valley of the Heroes
Can an improperly adjusted relay rod cause pulling problems? The link from the knuckle to the steering box. If not adjusted properly, could it cause damage to the steering box?
And.... does it need to be lengthened after a lift? I know... newbie questions, but I'm having issues and wanna hear the experts talk...
Not an expert, but the relay rod adjustment merely controls the position of your steering wheel. If by pulling, you mean that when the wheel is at center, she drives off the road, then perhaps you need to adjust it. However, if the pull actually turns the wheel, i.e. you can't comfortably drive in a straight line(regardless of the steering wheel position) without putting pressure on the wheel to keep it driving straight, then you likely have an alignment issue, stuck caliper, incorrect tire pressure, or wheel bearing problem.
I hope this helps,
Dan
I'm betting an alignment issue.... I've always had the issue since I've lifted the wagon, basically since I've had it. I've got brand new tires, I've overhauled the brakes, and also knuckles.
I just went out and adjusted the relay rod enough to make the steering wheel go a full revolution.... oops, big mistake, couldn't turn left! literally had half turn radius. So I put it back to where it was before the adjustment and lined the steering wheel with a slight turn the other way. I was just curious more than anything, that's why I went a complete revolution.
Time to learn how to self align an axle... Not ready to turn it over to the shop (you reading this Matt?) since if it's a matter of a few nuts, turns, measurements... I can do that.... and hey, if I screw it up, I can then take it to the shop.
off to the search function!
The only alignment you can do on an 80, (besides caster bushings etc) is toe.
I don't remember what the specs are, but you can usually get it pretty close with a tape measure....
As LT said, if you have any slop between the wheels, that could easily cause pulling. Can you describe your symptoms in detail?
Good Luck,
Dan
Good Luck,
Dan
Pulls to the left, no matter what. No matter the crown in the road, it pulls.
Tire pressure is dead-on.
Sounds like the problem I had when I went up more in lift. The pan hard bar needs to be corrected.
Even though they do stick out I always thought this had no bearing on tracking.
I'm sitting around 5" to 5.5" lift.
I just bought the DIY kit for the rear panhard actually, got it in today ironically.
Can I do the rear and not the front and see better results? Obviously not best results until I do the front...
swap both front tires with each other and take it for a ride.
brand new tires as of 3 weeks ago. Did it with all 4 sets of tires I've had post lift.
it's probably something basic that you are over looking. I know this is of no help but try and think of what you might have missed. There has to be some play in the joints somewhere to give you this pull, or your caster is out if whack.
Did it pull with the KM's on it? I don't recall it pulling last time I drove it...
I do know a good alignment guy.
Dang, do you have a homing device on me?
Yes, its always pulled, I adjust tire pressure until it tracks straight:o When you put the new tires on, you noticed it because ya'll correctly inflated the tires:rolleyes:
I can set toe... I think... but wondering if I should just wait until I fix my panhards before I adjust toe. What say the experts?
So you don't think it's because of the panhards?
what height lift do you have and what have you done about caster? The last thing I did on my truck was to correct for axle offset(panhards). I never had a pull issue and was at 4" of lift.
5-ish inches.... I've got Frankie's springs and they are a true 4" lift and I put my adjustable spacers up front and 1 3/8" spacers in the rear.
Slee castor plates, OEM bushings. Never have adjusted toe.
I'm now beginning to wonder if adjusting toe will even fix a problem like pulling to the left. My wagon doesn't really wander that much outside of just pulling.
LT, I just read in a post a few years back wher you suggest using tape even with the center of hub with a mark in the center of it to chec and adjust toe. I'll most likely use this method when I dig in, but I don't know if tis is my issue.
No. I've replaced my front pads a couple times since the pulling, all even wear, even replaced the rotors once.
