Related issues?
Olalla
Website
www.rhodescreations.com
I have a 95 FZJ80. Over the past few months I've noticed a strange grinding sound when starting... sometimes. I stop, then turn the key again... and it starts no problem. Figure missing teeth on the flywheel? Starter is relatively new.
Then today the battery light comes on. First time ever. I have two batteries and a marine isolator switch. Bad alternator I figure? But the belts are also toast... going to check fuses/relays tomorrow but I think it's the alternator. Good time as any to swap belts.
Just wondering if any of you gurus see something here that I'm missing that might tie these issues together. Just about 205k so I'm not complaining.
Cheers.
So when you hear grinding is the engine spinning or not? If so then the alternator could be the noise. Mine is original with 263k and I just replaced the brushes which still had 25% left and the bearings are smooth as butter milk.
Auto parts stores test for free. I know, removal is a bitch. Taking the distributor cap off helps access.
For the grinding noise You might want to climb underneath your truck to check the starter bolts. I seem to remember another thread were other members were saying they have seen them back out of the starter. One guy said one of his starter bolts was completely gone, and the other was holding on by only 2 threads.
The sound only happens when the starter is engaged. Sort of a grinding/chunky sound. Turn off the key momentarily and then turn it again and the problem is gone. Also, truck didn't want to start this morning... batteries are weak. Not weak enough to engage the isolation, but...
Picked up a reman alternator. Got the old one out okay (had to remove radiator hose though). New one is roughly in place but I can't get it the top pivot to seat. Can that bearing be removed? It's close but i'm hesitant to apply too much force. Any tricks?
edit:
Brute strength did the trick. Standing on the bumper and pulling straight up on the alternator seemed easiest. All back together and the new belts are installed. Added some Toyota red to compensate for what spilled when I pulled the hose. Started up fine. Seems to be charging. Going out now to get some beer. It's 90 degrees.
lesson: Should have gotten the beer before I pulled the old alternator.
