to ZUK
I'm looking at re-gearing my '96 FZJ80 as well. I'm currently running BFG AT 295/75/R16's (33.2"). I'm a bit torn between 4.88 and 4.56...leaning toward 4.88. My rig does a lot of runs up to Mammoth from LA, and a lot of dirt road surf chasing in Baja, so freeway miles more than rock crawling. Fiveo what ratio did you go with?
I will be doing mine in about a couple weeks or so, 4.88 gear, rear ARB locker, and rebuild front knuckle/axle, will report back after.can we get an update from some 3FE owners running the 4.88 and 33s setup. How has everything held up after XXXX miles?
Also, how many hours labor should I expect to be charged if I disassemble 3rd member? Guessing the total cost of this job has gone up a few hundred bucks since 09'...anyone done this recently?
Mine is stock geared and after I switched to 33's I haven't noticed any difference on the highway. Off road is a different story, it is an improvement! IMHO, I would not bother in re gearing.![]()
I have had my 91 on stock tires, 33s, 35s and now 37s. 33s will not make a difference on stock gearing.
