Refurbish turn signal switch?
Cleaned up the turn signal switch with a toothbrush and hot water. Used a hair dryer to dry out. Reinstalled and both turn signals are now working. Before only the right one would work. When testing to identify the problem, everything worked when the hazard was pulled. Identified that it was a dirty switch issue. Problem is solved.
Still can't get the horns to work. Will keep working on it.
