refinishing steelies
lebanon,pa
Website
www.facebook.com
i got a ball park figure of $200 for 4 wheels, sight unseen.
so what was type of finish was on them, gloss, semi, flat?
mine are off a 75, and no orginal finish remains. i planned on going with what ever dark gray i could find in their list.
were they colored all the way around, or just the outside?
just the outside, inside was black.
before going any farther, make sure you 75 wheels are welded no rivited, if rivited, don't bother as they are drum brake wheels. 75 should be welded, also check the date on the wheels
Powder coating is usually cheaper than paint, I had 4 wheels done here at work, $5 for powder, and approximately 1-1/4 hours to do the work. if it's a custom color though, your options are more limited to paint. I just went gloss black.
my choice: powdercoat, 60% gloss, dark gray
I primed mine with Rust Bullet and rattle canned them:
I had my spoked steelies from my '82 powdercoated white. Cost was about $20 per, including the prep work (sandblasted and etched).
Only downside has been, when tightening the lug nuts, the powdercoat is rolled up under the nuts, and removed in the nut countersinks.
Sure look good, though, with 33x9.5R15 BFG AT/KO tires.
Kirk
In my most humble opinion, the best match in powdercoat for original is Dupont Concrete Gray. Has a hint of blue green in it; matched it to paint on the inside of the tire that was never sprayed over. I know, I have said this before. But there are not many "Tech" questions that I can actually answer.
what size is tire is that?
i'm going with 33's, but not sure of width yet.
currently running 9.5 AT's on spoke steelies. thinking of 10.5 for the steelies might go back to MT's. wish they were still around in 9.5.
Em are 33X9.5 MTs; no longer made but at times you can find em used like I did (from another cruise head). ATs are still made. Swamper makes some tall narrows, depending on your needs. Also heard Khumo? makes MTs in that size, someone said look at tire rack dot com. They're pretty narrow but old skewl kewl. Best Wishes, DocB.
I've posted this before and I'll post it again - most advice I get now-a-days from various auto body shops in the NEast is not to PC rims. I have personally had two different sets of stock rims powdercoated by 2 different shops and both chipped alot within 6 months or so (minimal off-road use). Once they chip, the rust begins immediately. You end up painting over the PC to keep them looking half-way decent.
For the set I have now, I am going with Rust Bullet followed by rattle can as Yooper has done. Easy DIY (after I sandblast them) and even easier touch up mtce down the road.
Just my experience. Maybe both shops I used totally suck at PC. Who knows.
AndrewT
AndrewT
If they're rusting that fast, then the coater didn't pre-treat the parts, and/or you didn't ask for it. A good powdercoater will always use some type of pre-treatment and should ask a bunch of questions regarding final use. The two best pretreaments for corrosion are zinc phosphate and iron phosphate. Zinc will give better protection, but is more environmentally hazardous. Also, if they're chipping badly, the coater probably undercured the rims, and the coating is weak. You should really have a hard time getting a good powdercoat job to chip.
Thats good info. I wish I knew that before I paid the coin for PC jobs that don't last. As I said, I don't rule out the possibility that both shops I used were crap. This is NJ after all.
Both shops I used claimed they did a pre-treatment but did not specify type.
AndrewT
AndrewT
Sorry to hear about that. Powdercoating is a lot like painting, because there are good shops, and there are bad shops (like everything else). I've been doing some powdercoating as a side business for about 8 months (with a history as a coating engineer), and have run into a lot of this stuff. Education is key; and if people are more aware of what to ask/look for, then they will get what they want and need. :cheers: If you were on the left coast, I'd see what I could do to make it right. :D
decided to rattle can'em.
took one into work today to see how the beadblast cabinet would do. it worked pretty good, another one goes in tomorrow :cool:
it took about an hour to get this, the other side is about 90% of what this is, the rest i can get with a wire wheel on a grinder. would have taken less time, but the window on the cabinet is shot so you need to do a dance to see what you're doing and even then you still need to pull it out every few minutes to see just what is going on(or coming off).
Brian,
I ended up not using rust bullet and used a rattle can self etching primer from Dupli-Color. This was done after I blasted the wheels and then metal prep'd them. The primer was amazing and is very tough. I just top-coated this weekend with rattle can acrylic enamel (Dupli-Color) and they look great. Used their Machine Grey color which is almost identical to stock (I can't tell the difference).
I hope they wear well. Time will tell. Plan to mount them up this weekend.
I'll post up some pics later.
AndrewT
Some pics............
A few pics. Top-coat is color DA1612 - Machinery Gray.
AndrewT
made in April of 1975 :)
