Reese Universal Recovery Ring
it's elegant but it's not obvious that it has any major inherent advantage over an insert with a shackle, aside from maybe weight for the same rating. Do you know what it's rated at?
x2, weight rating?
It was rated at 10,000lbs. The swivel feature seems nice so you don't have to worry about side-loading your shackle.
never seen one in person but judging from what I assume is a 2" insert, it looks pretty beefy. Not too expensive either. I'd be curious to see how the swivel is held in place. Couldn't find the gizmo on the Reese site.
So I've have had one in the 80 now for quite some time. And the things great. There were a few times that were iffy but has held up over the past year
Glad to see this thread, I ran into the same thing at Walmart, looked like it was held in by a large nut on the inside. It did specify no shock loading. Does this include Bubba ropes or snatch straps? That's not really shock loading right?
That is the epitome of shock loading.
Anything besides a gentle, static pull is shock/dynamic loading.
...via IH8MUD app
I always thought of Shock loading as what you would get with slack in a chain or static tow rope, and then a sudden pull resulting in a very abrupt shock load. The other would be Dynamic loading.
You can find similar items from warn and others....Might want to compare items before you purchase....seems to be some minor mfg differences that might make a difference in use.
Static pull or loading = line is taught and you being pulling without slack in the line.
Dynamic/shock pull or loading = line has slack and when force is applied the slack first is taken up (often very quickly) and then dynamic loading or a shock force is applied once the slack is gone.
