Red line's 80 front bumper prototype
Hey, had you guys considered making DIY kits? I think those would sell like hotcakes as these look to be a good alternative to the ARB. Nice work.
We have not, thought about that. it will come up today sometime at the shop!! we shall see!
Thanks
Justin
check this one out, I like it! a mix between and arb and a slee!!
Justin
#3 prototype
Justin
#3 prototype
Much better on the tube. My only comment would be if there is any way to tuck the lower part up more?
X2 on tucking it up, but it looks great so far.
Bars look a lot better. But one question, why do you have the recovery points pointing out at an angle?
Paul
I knew I shouldn't have been so hasty to buy the Shortbus. I really like the center hoop. Trim it up for better clearance and then start on a rear bumper!
wow, Slee has a point, as soon as I saw #3, I immediatley thought Shortbus bumper. I'm glad another bumper option is becoming available, but man does it look similar to Slee's.
justin i think ya'll are doing a great job! keep up the good work. don't worry about haters...just keep grindin..
X2 keep up the good work. I like the center hoop.
IMHO the angle on the lower is too vertical, angling it back like the green line would be better. As it is when it touches an obstacle it will be like a wall, with some more angle (45 degrees?) it would allow the rig to slide up, that would also make the bumper stronger. Look at the two frame-bumper bolts, they are at an angle, nipping off the lover frame corners outside of those bolts would allow for much better angles.
The side wings hang down too far, bringing them up somewhat like the line in the second pic would make for better clearance and less bulky looks?
I like Tool's line on #3 and Nay's comment. More holes in the lower skid plating would be better/lighter as well as promote more air flow which never hurts.
When is the production run on #3?
soon, very soon, we want to get these out asap, just acouple more things to go through!!!
Justin
its easier not to run a winch in a winch bumper than to run a winch in a non winch bumper :D
looking good, how much could you trim up the bottom edge of the bumper, to give it a less bulky appearance, or curl it back and under for less hangups when backing. Looks good, just a hair bulky, but very nice.
