- Joined
- Sep 19, 2007
- Threads
- 145
- Messages
- 1,531
- Location
- Colo Spgs Colorado
- Website
- www.redlinelandcruisers.com
Red Line Big Brake Kit, Front Landcruiser Upgrade, FJ-40,45,55,60,70 Series
Tired of not have the brake performance on your land cruiser? Have you upgraded to 35,37″ Tires, a V8 ? Well, This brake kit is for you. It’s the only kit of its kind for the solid axle land cruiser on the market. Red line had developed and tested this kit 5 years ago on ” The dogs Bollocks” What we found was the best solution to get your land cruiser to stop! This kit will keep you in control, no more pre braking before a stop light 100 yards out and no more double pumping!
Listed below are some requirements and specs that are included in this kit. Remember that with this kit it is also very important to have a balanced braking system. Rear disc brakes, a 1″ Bore master Cyl and a dual diaphragm brake booster is advised! We also sell those components for your cruiser!
This kit is designed to fit toyota solid front axles up to 1990.
- Requires 17″ wheels at minimum ( Call for 16″ wheel Big Brake Kit )
- 13.30″ diameter cross drilled and slotted rotors<2> Compare to Factory landcruiser rotor is 12″ in diameter
- New aftermarket rebuilt high quality Toyota v8 calipers<2>
- New Performance brake pads
- New 17″ rubber DOT brake lines<2>
- Front wheel bearing rebuild kit < KOYO wheel bearings and gaskets>installed
- Machined IFS wheel bearing hubs< cleaned and ready to install>
- New Lug studs<12>installed
- Custom Caliper Brackets with hardware
- Allows you to swap Birfields in 15 minutes
- Will widen front Wheel mount dimension by 3″ or 1.5″ on each side
- Includes instructions for easy installation.
- Perfect kit for v8 power and 35″ + Tire size.
- Warning this kit will stop your cruiser like never before. SeatBelts are required
- For proper brake bias and balance, it is recommended that you run rear disc brakes and 1″ bore master cylinder and dual diaphragm booster, see our brake conversion parts
- Detailed instructions RED LINE LANDCRUISERS BIG BRAKE KIT INSTRUCTIONS [PDF] Price 1599.99$
