Recommended flasher for LED conversion
Just my experience, I ordered the cf13 jl-02 off amazon for my 94, but had to use the jumper from my old Toyota switch to flip the relay because the positive and negative were on the wrong sides. In my case the Cf14 would have been the actual correct relay.
Fyi
If you swap out the 1156 rear brake lights for leds, some people loose cruise control.
Old thread, I know. The cruise control module supervises the brake light circuit. It imparts a small voltage on the circuit. If no current flows the module assumes the brake circuit is not connected and won't function. If LEDs are installed to replace the 1156 lamps you must install ballast resistors at the lens locations. Some of the newer LED 1156 may have a resistor incorporated in them.
