Rebuilt engine
upstate SC
Can someone give me a ballpark estimate of the cost of replacing an engine in an FJZ80?
I can think of two scenarios.
1.) Pulling the engine myself, rebuilding it and putting it back in.
or,
2.) Pulling the original engine and sticking in a used, working engine.
I know the cost would vary based on what was wrong with the original engine, etc. I just want an idea before I commit to anything.
Thanks...
or,
Thanks...
I've spent about $2600 so far. That's with me pulling the engine, reinstalling it.
Are you considering buying one that needs an overhaul?
Yes, I'm looking at one that may need an engine overhaul. I have access to the tools (engine stand, lift, etc.) and friends with the know-how. I just wanted to be realistic if I make this person an offer on the vehicle.
Covering the same ground myself, 3 ways to do it and if you have a budget then there is only one way to do it. If you have money reference option A.
A. Go to the shop, have them pull your motor. The ship it to Man-a-Fre and have them rebuild it for $3995. It will be a ZERO time engine when it comes home. They do a very nice job. Have your local shop re-install the "new motor". Total to Remove and Replace should 20 hours give or take. 20 X $70 (Labor Rate) = $1400.00 + $3995. = $5395.00
B. Go to Junk yard and pay for used motor. Cost can anywhere from $1000 ot $2500. Go to shop and pay the 20 hours of labor and you're all set, that is until you need to do the HG.
C. Using some of option B. Go to junk yard buy the engine and install it yourself. It's all a matter of ass pain and down time at this point.
And there you have it, and don't forget while the engine is out you might as well replace some of those nuissance items, such as the PHH, starter, alternator, water pump, belts and anything else you feel like messing with.
My engine has 217K on it, the main bearings are rattling and number 6 is taking water. Rebuild, refurb or punt??
Good luck, we're all counting on you!
217k and bearings bad? Sounds like someone ran out of oil.
Replace the head gasket, set the valves and drive on. Rattleing sounds more like valves, how is your oil pressure?
IIRC, couldn't you still see the cross hatching on your at 220k? And NO noticeable wear on the bearings that came out? I'm going to second the idea the if its failure its due no neglect or extenuating circumstance.
Right P8nt. As a matter of fact, the machine shop was truly amazed at how new it all looked.
CDan had previously advised me to leave it alone, and if I had listened to him I would have saved a couple thousand and had the rig on the road last May! :doh:
VT92,
I would try to keep the original engine. It's always better for resale if you do, and at least for me, it makes it more interesting than if you have to junk the original.
That said, to each his own.
A solid diagnosis would be valuable to you here, as previously mentioned. Most of the time, the 1FZFE is bulit-proof, and hard to kill. My OH was pure over kill on my part based on a bad assumption that it would need it after 225k.
Your "rattleing" sound could be anything from timing, to pre-ignition, to valves out of adjustment, etc.
HTH,
DTaylor
I could have just a well been wrong Dan. When you get finished that motor will last you the rest of your life.....
:cheers:
