I posted this in the 80 series tech section but I rarely get traction there. You guys have always been very responsive and helpful so here goes.
Need advice from the forum with regards to replacing the Head Gasket, Rebuilding, or even replacing the engine:
- 197,000 miles, no HG job that I am aware of
- Bubbler test comes back clean after 15min
- Blackstone shows medium levels of coolant in oil (not high, not trace either)
- White smoke on startup then it goes away
- No oil leaks
- 1qt of 5w30 burned per 3,000 miles
Given this setup and situation, and knowing that you want to drive the truck for an additional 200,000 miles, what would you do?
- No oil leaks
