Rebuild or Replace CDL Actuator Motor?
SAS
Seeking higher vistas
Colorado Springs
Pulled the CDL actuator motor off the '94 FZJ80 transfer case after diagnosis indicated the motor was bad (went through steps outlined in PNW Backroad Adventures, and numerous threads here in the 80 Tech section).
Opened the case and found that the gear and bi-directional spring were in excellent condition, with OEM grease still looking good. I then pulled the cap off the motor/worm-gear, and found the fault--it is burned up.
I've read where some motors were salvageable with a little cleaning and re-soldering; I'm afraid mine is beyond that (see pictures). The base or "circuit board" upon which the copper braided pigtails and "parts" are mounted was severely burned and disintegrated. The wires inside the housing were severely burned as well, but amazingly still carry current (tested with 9V battery).
So what are the options to remedy this motor? Does Toyota sell the parts to rebuild the "circuit board" and the braided pigtail "parts", or do they sell only the actuator motor assembly?
Could a local auto electric shop rebuild the electric motor--such as an alternator shop?
Suppose I can start browsing the parts and parting-out threads for a HF2AV donor? This case is common to all FZJ's right ('93-'97)?
Update:
Bought a salvage yard replacement and swapped the actuator motor and the trans relay that I had bought some time ago (OEM tested bad).
Did the Pin-7 Mod and installed a early 90's Tercel hazard switch to round out the new set-up.
Works like new. Thanks, MUD, this is a :banana:job that I put off for way too long. (i'm skeered of 'tronics!!!:hillbilly:)
