Rear wiper motor ghost
West MI near GVSU
Website
www.mcdesignsoffroad.com
I just picked up the 80 from a week in covered airport parking and heard the rear wiper motor groaning. It has never made the wiper work, but yells at me if the switch is accidentally on.
Tonight I hadn't switched it on. The rear defrost was on, so I switched it off. I switched it back on and the wiper motor stopped. switching the defrost off would turn the motor on, and so on. It didn't make a difference whether the wiper switch was on or off.
Is there a magic wire I should look for that may be shorting out?
I just disassembled a 93 hatch that I smashed and in doing so, I learned that the wire harness comes from the upper corner left 'D' pillar, through the gap grommets and into and down the left end of the hatch. All those wires are touching each other down the left side and across the bottom of the hatch. It's possible the defroster wire and another wire have chafed and are now swapping electrons. You can drop the headliner to access the wire connectors in order to pull them up and out of the hatch or just to do continuity checks. No magic going on though.
^^this was going to be my recommendation. I had a similar problem with a 4Runner years ago.
Afraid I can't be too much help despite my own recent foray with electrical ghosts. It's an interesting problem. If Defog ON = Wiper OFF, it says to me there is a current leak to the hot side of the Wiper relay and turning on the Defog offers a better path for that current to follow. This would make sense if the Defog relay had switched hot AND ground, but I think it is only a four pin relay which would mean switched power and common ground. I suspect there is another current leak (always hot) somewhere (say, wiper motor power supply, pre-relay) and the Defog/wiper issues are symptoms rather than the disease.
Since it happened after the truck had been sitting for a while I would suspect this was corrosion related rather than a wear issue though i wouldn't rule it out either. Having said all that, I found my electrical issues after an exhaustive search rather than through clever trouble shooting.
Good luck!
