'93 Landcruiser, rear window washer over the last couple of years slowed down to a drizzle and the finely stopped. I figured it was time for a new diverted valve so called Beno and got one in, swapped it out. No dice, still no flow on the rear window. So I start pulling hoses and try blowing compressed air in the line and still no dice. Then I get some thin wire cable and start running it down the line. I find all the junctions and work my way back towards the rear to where it stops. Then I try working backwards from the rear washer with the cable. I find the first check valve, looks good. Finely discover the second check valve under the jack....bingo - found this jammed up in the check valve like a tiny sliver - I have no idea what it is: maybe a gasket from the old diverter valve?
