Rear Widow Sprayer Blocked.....
37° 52' 18" N / 122° 16' 18" W
The pump works, as it sprays into engine bay.
I disconnected hose at rear tailgate.
Tried to blow air through line from front.
Nothing.
I tried blowing air from the rear and it blew the black rubber hose off the black plastic elbow under the rear headliner.
Right now the line is disconnected at the pump and disconnected at the black plastic elbow that connects to clear tubing where the tube exits the interior of the body.
Air will not pass from either direction.
I can see my clean out wire pass through the rear elbow into the clear plastic.
Where might the likely blockage be between the firewall and the rear gate?
Where are the other connectors?
There must be at least one that connects the black rubber tube from the pump to the clear plastic tube seen in the rear.
Thanks!
Cheers!!!
1992
On mine I had a plug of paper towel or something in a barb fitting back under the jack on the LH side. Pain in the azz to see, but a cell phone camera should help.
You will find other lines back there, but they are unused as they are for the "barn door" setup. Don't get fooled by them.
Are you sure it's not the diverter valve near the brake booster? Mine failed and would only spray the windshield.
1992 is going to have two pumps, no diverter.
