I thought I better have a look at what might have been making the knocking sound on the rear ight side wheel, when I jacked the car up, I thought I better check for any movement in the bearings by moving the wheel, and it moved very slightly? even when the wheel was off, you could move the hub back and forth about 20 thou
So removed wheel and decided to take the bearing cap off, god! them coned collet sleeves were a cow son to get out, really had to hit the edge on the cover to get them to release, (anyone know an easier way to release them? )
After I had reomed all nots and cones, I was tapping the cover to remove it, and as it started to come away, diff oil started to come out, I assume that diff oil should NOT be in the bearings? The oil was really clean! and was as new, I would have thought it would have been black if it had come into contact with the bearing grease?
I decided to tighten the cover back in place, as I did not have a gasket to replace it with, and I could see that if I carried on getting the cover off, it would have destroyed the gasket.
I did a rebuild of the birfs on the front about 2 years ago, but I have never checked the rears, I only changed the dif oil.
I have done a search for rear bearings, but nothing really comes up, has anyone got any hands on tips that I will need when I tackle the job, what parts I might need in doing a rebuild, are the bearings like the front? and need to pre loaded ect ect
