Anyone have a nice rearview camera set up for an FJ40. Mounting point, wireless, hardwire, forward and back etc... ? Looking to tow a small boat and or trailer and would like to see what's going on while traveling down the road or backing up.
I got the Wolfbox G900Tripro. I've seen some video of people mounting the third camera under the car to make sure you had adequate clearance over obstacles - pretty cool!What brand and model is that? Having three inputs is convenient.
I could see putting in a camera like your lower and a front bumper camera in addition to the rear high mount camera.
Thanks for the details. That will be a good replacement for mine when it decides to quit workingI got the Wolfbox G900Tripro. I've seen some video of people mounting the third camera under the car to make sure you had adequate clearance over obstacles - pretty cool!
After playing around with the camera more, I learned about tilt and panning so probably didn't need the lower bumper camera. It is a little slow to access that functionality however and the way I have it setup now I can just swipe the screen and I can easily toggle between cameras. The tilting function requires a press and hold on the screen and then use an arrow to lower the view. Not that much longer, but when backing up I'd rather have quicker access to that camera.
FYI - the three cameras are - 1) built-in to the mirror front facing 4K camera; 2) rear camera mount wherever you want inside or outside 2.5K; 3) third cam is a 1080p camera (the lowest resolution) and again designed for anywhere. The cable they provide has a more rugged outer shell so it clearly is the one that they expect you to run primarily outside. I ran mine under the car inside the frame.
