Rear View Camera Trigger Help
Nice. Are you also tapping into the black and white wire or just th red and black. Can you send a pic?
Sorry I didn’t take pics. Just the red/black. I had a wire for the parking brake but couldn’t figure out where to tap into for that so I left it alone. Doesn’t affect functionality.
@SLCFZJ after you installed the head unit, do you hear something after you shut off the engine "whirring"? I believe it's the antenna, which has never worked in my truck. I purposely did not connect the antenna wire to the head unit for this reason.
Maybe it's not the antenna. Hmm...
Update. After everyone’s input and finding some time I opened the dash up and checked my wiring. Everything looked good and connections were fine. I jumped to the back of the vehicle and started double checking everything and found the red wire that is connect to the rca wasn’t connected to my brake lights for the trigger. Stupid mistake but easy fix. Thanks for everyone’s help.
Now I need to figure out why the power antenna doesn’t work. I still have the blue wire from the harness that is loose. When I hook that up to other blue wire the antenna goes crazy and the deck doesn’t work.
