Rear upper control arm bushing part number
allentown pa
Hello, I'm currently deleting the failed/rusted out AHC suspension and finding everything else that's shot on this 250k 25 year old truck... Rear upper arm bushings are shot and id like to replace with oe parts if possible.
I'm finding that Toyota does not list bushing separate for the 100 series but does list them for the 80 series cruisers.
80 series rear upper arm bushing is 48702-60031
Does anyone know if this will fit my 100 series?
I also found cruiserteq.com list a oe Toyota bushing for 100 series but does not list the part number.
Sorry if this has been asked/answered already, this is my first post on here.
Why not order them from Cruiser Outfitters that you found?
I work at a Toyota dealership.
If I can confirm the bushing part number, I will just order through my dealership.
you'll need two bushings, and if you look at the oem arm, it may be few $ more than buying two separate bushings.
The 80 series bushings have the same outer diameter as the 100 but use an 18mm bolt (vs 14mm).
The OE upper rear control bushing part number is: <48702-60090>
But it is not a North American part number and even you might not be able to order through your own dealership. Like @nissanh suggests, I just replaced the R-UCA assembly.... saved me an hour+ of cursing, getting those 4 bushings out.
