Many thanksThe part diagram calls the bar "stopper". I think they are only used with the subtank.
Diagram:
This thread shows how the small one is mounted. If you look at the rear of your Land Cruiser you should be able to find some captured nuts for the long bar.
I am looking at Georges excellent write-up on the Sub Tank install and have a few questions for those that have done this:
http://george4wd.taskled.com/auxtank.html
1) What size drill bit to drill the whole for the other two Rivnuts?
2) It would seem you would want to do the first two Rivnets, install the brackets and test fit the tank and mark where the other Rivnets should be drilled/installed. Is that correct.
3) What is the pinnout of the existing sub tank connector that mates with the subtank and what wires do they match in the harness near the existing fuel...
- Romer
- Forum: 80-Series Tech
