Has anyone done or seen a storage compartment built into the read deck? I was looking at where I might be able to add something like a metal or aluminum box fabricated to fit underneath the rear deck where the spare tire normally stows, and then cut out the deck to access the box and install a hinged access doorthere in the back floor. I have been thinking about trying this but wanted to see if someone has already done it or has information that may be helpful.. There is already about a 12" Sq pannel spot welded and sealed in the floor and that looks like it would be a good place for the access door. The door opening of course would not have to be as large as the box, but just enough to be able to fit whatever gear might be intended. There sure is alot of open spane under there with the spare tire and probably the cross plate which holds the tire removed and there is not much else there. Probably build it wide enough to fit between the two l body beams. Anyway, curious to see if anyone has attempted something like this.
