rear sil replacement
I had mine made up by some small sheet metal shop for 35 bucks and it is thicker than the original. I just cut out the original and brought it to the guy and a few days later he had it done. The big shops would have charged me 3 times that because they have to pay their employees. Good luck Tom
Really depends on the year of your truck, and the extent of the rust/ earlier trucks are easier, basically just an ell shaped piece , midyear 75-78 require a more complex piece, and the post 78 trucks involve the rear body mounts, as they are bolted and accessed thru the rear sill. Mid and late trucks have a double metal piece, one sandwiched inside the other, which go on to include the outboard mounts. You need access to a air cutting wheel, and mig welder to do a neat, accurate repair, along with some fabricating skills if your rust extends beyond the sill.
Candacruisers.com x 2,
Great fit and finish...
my bodyshop guy has used them all and mentioned just recently that the Canadacruisers sill is by far superior
x3 for Canadacruisers.com. Their sill has two pieces:
a 2 X 4 inch (~1/4 in. wall) to form the main structure of the sill, and a 14 guage piece that has the contours for the lower edge of the doors/weather stripping.
The way Spencer has designed the panels, you don't need holes in the 'contoured' sill to access the rear-most body mount bolts (they get installed from the bottom), thereby eliminating a way for dirt/sand/salt/water to enter your sill and rust.
I've used them on mine, and was really happy with them. (No shipping was a bonus for living 20 min. away!!!).
Cheers,
Steve
PabloCruise said:
Are you just talking the sill, or the rear channel that the sill sits on?
The channel is frequently rusted. It supports your rear quarters (and the weight of the hard-top) as well...
I got mine from CCOT
I'm pretty sure it is just the sill.
