Rear PTO
SoCal
Can someone point me to a written, and hopefully visual, source online that explains how the rear mounted PTO works?
Next, would a rear mounted Confer fuel tank exclude a rear PTO setup?
works the same as the front if your puting a winch on the back the tank will be in the way dont think there is any standard way to do this because not many people run the rear pto good luck
Doesn't have to be the rear - you can put a PTO anywhere that imagination, universal joints, and bearing carriers allow. On the roof PTO? Sure. On the side? Sure. Both sides at once? Sure, use pulleys and a looong winch cable and fairleads all over to make one winch pull from any direction you like.
Sound crazy? See andrewfarmer. (mentioned with much regard for andrew's ingenuity as applied to his awesome cruiser)
check out some german military vehicles rear and center mount ptos are not new the germans used them in and before ww2 some mounted in center and pulled front and rear some mounted in front and pulled both ways using rollers pulleys and cable diamont t truck had a winch in the bed and pulled front or rear there are many options on mine i mounted the winch under the back then made a drive shaft to fit i dont do photos still trying to figure out how to buy a star good luck
