Rear pinion angle with 4 link
Kent
Pedal Head
South Dakota
Doing a 4 link rear 76 FJ40. I've searched and read a lot about driveline setup including Tom Wood's site. I understand pinion and transfer case output shafts are to be parallel or within a degree or so of parallel. I didn't measure mine before removing the rear axle. Ooops. My question is how do I set the angle with the axle on jack stands and the vehicle up on blocks?? I've leveled the vehicle but does the height placement of the axle affect the pinion angle? I am thinking it does so how do I get the correct angle set in relation to the transfer case when I can infinitely raise and lower the axle on the jack stands compared to the vehicle frame. I will be welding the spring buckets in place on the axle and if I am not mistaken they will be placed level in relation to the frame once the axle is rotated a few degrees to register the correct pinion angle. Maybe I am crazy and I just need to set it and go. It seems to me the axle moves in a slight arc though when it flexes through it's travel so the pinion angle will change slightly depending on where the axle is in space. Since I don't know where it will sit with full weight and ride ready, I'm scratching my head on how to determine where that will likely be so I can get the angle set perfect when in that position. I'm sure by now it's obvious this is my first attempt at this!! Thanks
Howdy! Just trap the axle perches between the springs and the axle housing and set the full weight of the body down on it. Then rotate the axle housing around until the angles of the two flanges match. TAck the perches and then pull out the axle and weld it solid. John
Ahh makes sense, great info! Thanks!
So that brings about another question.....
If I am thinking correctly I should tack the perches to the frame and axle to set up the 4 link and get the axle positioned where I want it (5 inches back from stock) then do what inkpot has suggested with setting the truck down on the axle.
Keep in mind this thing is stripped down to frame, engine, cowl and driver/passenger compartment only. Everything else is on the floor of the garage.
If I understand inkpot correctly, this will be one of the last things I do before actually being able to drive it away. Body, cage and everything must be finished to get the real time weight of the truck down onto the axle to get this pinion angle set correct.
I've spent a LOT of time reading here and it's slowly starting to come together..........
Thanks!!
