Rear Main Seal replacement??
lar
Knoxville, TN
Project "Gary" finally got up and running last week. Unfortunately he is slinging oil off the fly wheel worse that a fresh oil rig!!! I read several post that suggest several ways to do this job. One post mentioned going at this job by removing the oil pan and #6 main bearing cap then pull out the seal and push back in. Has anyone attempted this repair this way??
Any info is greatly appreciated.
Kevin
Removing the trans, oil pan, and #6 main bearing cap is the preferred method.
I'll note that the present day OEM rear mail seal has inner lips facing both the engine and the trans.
I installed this seal with a light coat of oil on the interior of the seal and it began to "squeal" loudly after a few weeks.
I squirted some grease past the lip on the trans side and that cured the problem.
