Rear lower shock mounts/spring perch
Providence
Much to my dismay one of my rear lower shock mounts broke off and I need some assistance. I did some digging and it looks like the lower spring perch is NLA from Toyota which sucks because the shock mount is integral to the perch. Is there a revised number I'm not finding or am I SOL? If it's not available anymore does anyone have suggestions on replacements? Maybe a machined stud that can be welded into the existing location, or an aftermarket perch? Has anyone used the ones that SOR sells, the "extreme U-bolt skid plate"?
These are the original Toyota part numbers:
48046-60050 Right Side
48047-60050 Left Side
Search eBay. There’s a right side available new.
They both have been discontinued by Toyota but some vendors might have old stock. Also check Amayama
The 70 series part is available new and works fine. I think they’re about $70-80 per side. I can sell you one or a pair if you like.
I just sold @jesus888 a set for his 40 project.
I also have U-bolts, shocks, bushings etc
