Rear Locker
So, tools needed:
ME, the biggest tool
9v and 12v (just in case) Batteries
Ohm meter?
and I guess regular hand tools from what Ive read.
Sorry for being so needy, I just dont like stopping midway realizing I have to go to the Auto shop to pick something up.
Thanks for the boost of confidence on Red Cone Romer, I was waiting for a comment from you on this. I'll be using every bit of info thats thrown at me.
I should have mentioned before, this happened on a trip to Kenosha Pass area- did Georgia Pass and Glacier Ridge side trails along with Middle Fork Swan River and Webster Pass if my memory serves me right. Fun trip and thank goodness nothing broke!
Sarahs Truck had a different problem where the locker would engage ok, but then would not dis-engage until it was driven on for a while. We took it apart back in camp and the spring and actuator where installed incorrectly.
Have you tried engage and disengae with the locker switch and have someone stand there to see if they hear anything?
Id get it unlocked and take your time isolating the problem
I stood outside the truck myself, had my wife engage both and then disengage: I clearly heard the front locker disengage. I heard a click from the rear as if it was trying to disengage, but it wasnt the "normal" clink that it makes. So Im thinking a sticky actuator.
PS- love the Avatar Romer.
I would take the actuator off, dis-engage the locker and then photograph the actuator taking pictures as you disassemble and clean. Sarah's all had lost the O ring so it was pretty dirty where the spring was and it was the spring that was installed backwards.
Spring went the other way, cleaned surface with an emory cloth and used black FPIG in place of an O -ring putting it back together. Robbie diagnosed and gave instructions
Thanks - Big Sluice on the Rubicon
Will do and I'll make sure to post pics up. Thanks for everything guys.
Well, got the locker situation figured out today. I did the 9v battery test and clink, the actuator did its job and unlocked the diff. I searched under the rig for the culprit and didnt really find anything. After putting everything back together I took her over to a field just to see if it was fixed or was going to act up again and so far so good. I locked it up fully and there were no problems afterward.
I have no idea what went wrong that day, and Im thinking this may not be the last I see of this, but for now everything is working fine. Thank you guys for all the tips and Romer, Ill see you on Sunday!
PS- I had to take the LX over to a friends to use his Jack stands and forgot the camera, so no photos.
Cool, hope that works. You might want to give it some extra excercise, that might loosen it up.
-Spike
Could just be there is crap in the actautor and it needs to be taken apart, cleaned and properly sealed.
This still does not answer why the rear lock mechanism was actuated by itself or with the PWR button. There has to be something else wrong with the electrical circuit.
-B-
It may not have been actuated by the 'power' button- in fact, the chances are extremely slim that there could have been a short between two power wires on completely different circuits. More likely that the actuator arm was in between its 'locked' and 'unlocked' positions, and happened to move over to hit the sensor switch at the same time as he hit the button, or he happened to notice it just then. Still leaves the question of how it got that way, it might be sticky and not have moved all the way to its 'unlocked' position after he last used the locker. It would be a good idea to open it up.
-Spike
I for sure am going to disassemble it and try to get to the root of it, because Im almost completely convinced that theres a short somewhere. It locked at the exact time I pushed the button so who knows? I didnt see any exposed wires or anything that would indicate such a thing, but then again I didnt break into the console either. Just another project to help me better understand my baby.
