Rear locker actuator
Belgium
I recently purchased an 95 80 series diesel with fr and rr lockers.
The front locker works fine, but the rear appears to not working.
When I switch the front one i can clearly hear the actuator motor running and locking the diff.
When lying under the truck and I switch the rear locker, i hear a faint "click" or "tick" coming from the rear locker actuator. I tried tapping it to see if it would come free or something but doesn't help.
The relay in the cab clicks aswell.
Is this a known issue?
I've read some threads about the actuator rebuild but the timing part is buggering me ( English is not my native language)
Does anyone have well explained and illustrated write up about the locker rebuild and timing?
Or could something else be my problem?
Thanks !
I tried removing the actuator to rebuild it, but offcourse the upper 2 10mm bolts' heads are rounded, so i can not remove the actuator completly.
Instead I started by removing the armature housing with the magnets in, I found out the magnets are broken.
So i'll try sourcing a second hand actuator just to replace the armature housing with the magnets.
But what I wanted to know: i tried moving the actuator by turning the armature around by hand, it does move , but do I have to "time" it again now that I have turned it by hand? Would the relation of the worm wheel to the gear be out of whack now that i spun the wormwheel around a few times?
You turning the wheel will not screw up your timing only if you open it up and lifted the worm gear. The motor does not directly move the rod, the motor puts tension into a spring that moves the rod when everything is aliened in the locker itself. Dont let timing scare you I have posted somewhere (search) how to time it without using a meter. I have several electric meters and have years of experience using one and I find timing without it is easier. I will encourage you to do what you need to do when it comes to getting the actuator off to service now and down the road easier. Also more searching may leed to a magnet source for the motors.
Hi,
When you say your magnets are broken.
Do you mean that they came loose?
If so you can glue them back in.
There are threads on that.
I'm not sure on the timing question.
So I'll leave that for someone else.
Good luck,
Joe W
I figuered out that the timing is NOT out of wack, and ik can lock and unlock the diff by turning the armature by hand, i also check the continuity between the 4,5 and 6 pins and that also verifies it is working.
Now I just need another armature cap with magnets.
I THINK I glued the magnets in the way they came out, but the motor would not spin, as before I opened it up it did make a faint click when I switched the locker on.
So i think I may have glued the magnets in wrong or maybe too thick glue or something. I tried removing them again by heating the glue but whilst trying to remove 1 i broke it. Stupid, i know.
