Rear locker actuator assembly
Godwin
Resident Herpetologist
Alabama
I've been all through the rear locker actuator in an attempt to get it to work but I'm still not there yet. In pulling it apart what I discovered was that the interior was corroded, the shaft was frozen, and a couple of magnets for the motor were loose. I cleaned the gunk out, loosened the shaft, and a shop worked on the motor.
I have not tested the motor which I know I need to do, but my posting of this is for some feedback on the reassembly of the large gear within the housing. In putting it back in I have it set so that the multimeter gives a reading of "1" between the #4 and #5 pins. If the gear is rotated counterclockwise one tooth the reading drops to "0". In order to install the gear in this position I have to rotate the cover counterclockwise a bit, which puts tension on the free-to-lock wait spring.
Am I on the right track with the positioning of the gear? I've read through the locker actuator threads but am still unclear on this one aspect.
when putting the actuators back together I don't worry about how the gear sits inside. This is because when you plug in the actuator and start the truck if that gear isn't in it's home position it will soon be as the motor will turn on and rotate it there.
This goes for both front and rear actuators so I always plug them in outside the housing and home them first. And then of course you can check their motion by turning the switch.
Ok, so I can reassemble the actuator, plug it in, and allow it to rotate to the home position. But in all likelihood the shift rod will not be where it needs so at that point is it a bit of trial and error with disassembly/reassembly to set the shift rod at the appropriate depth?
