Ive been digging into why my rear wiper hasnt been working. After troubleshooting i can get the motor to run by grounding the upper liftgate / hatch with a jumper wire. There doesnt appear to be a ground wire from the body to the hatch witch makes me believe the latch is supposed to ground the top liftgate to the bottom....Is that true?
I removed the latch mechanism from the upper hatch and there appears to have been a wire connected to it from the factory but it corroded off leaving only the wire and the terminal on the wire as evidence. That wire appears to ground the overhead/dome light which sits just inside the hatch when its on the setting which turns the light on when the hatch opens i assume. This makes me believe the upper hatch is grounded, through the lower hatch, only when it is closed. If this is all true, then is my upper liftgate not grounding because its missing whatever part/ connector the wire was connected to on the upper hatch latch?
I can ground the upper hatch with a jumper wire connected to the body of the latch, but not by connecting the ground wire to the moving /mechanical part of the latch that actually makes contact with the lower hatch...
Anyone know what im getting on about?
